Kitfox 4 rebuild
246 posts in this topic
Hi guys,  just weighed the plane and I'm at 624 empty.  And that's with grove gear and a heavy lawn tractor battery.  Got a couple small things to add, like pitot tube from wing to ASI, and fuel lines from wing tanks to header tank.  Don't think it will add up to 10 lbs, more like 5.  I'm one happy camper.   WAHOO!!!  JImChuk
Wow. that is light!!!
You musta done somethin right
Edited by FireFoxIV
Light and looks nice better leave that one in the hanger.
Forgot the prop.   Add 10 more lbs... Still light though.  JImChuk
Jim, I appreciate that you've maintained this thread along with your build which is outstanding.
I was looking at your wingtips and wondered what / how they'd be finished.  My present project involves everything but the wings but were I doing them, I was thinking I'd go with fences instead of the traditional tips of rounded and drooped that have been customary. The evidence indicates they improve wing flow over most all type wings.  I'm definitely considering them on the HH wing.  In your case you'd have an STi looking KF.
https://gtae6343.fandom.com/wiki/Stall_Fences
Paul
Edited by allonsye
I'm using the old drooped tips that came with the plane.  I do like the speedster tips for appearances, and they aren't the head bangers that the drooped tips are.  Then again, the drooped tips may save the flaperon in a ground loop.  Maybe I will mount a small wheel out there on them for just that purpose.  (just kidding on the whole ground loop thing)  :lmao:  JImChuk
The more I look at your plane the more I think I may have to go with a smooth cowl on my IV rebuild. It just look soooo nice.
Wow, you did get that cowl pretty low. Great viz! :BC:
Got the parking brake in and fluid in the lines today... Have to wire up the engine monitor senders, and tie off the wires and such, and then the panel will be pretty well done.  Maybe I will finish this plane some day yet!   JImChuk
PS  had to come out of the side of the valve on the closer line cause the elbows I had didn't clear the lever.  It works though.
I needed to revise the parking brake.  This is the location where I mounted the one in the Avid, but the Kitfox fiberglass seat hangs down further, and the seat hit on the parking  brake valve when I moved the lever back and forth.  This is the new location, tucked up right behind the seat truss.  JImChuk
Still not flying, but am making some progress.  Although when the just painted, still wet boot cowl fell off the table yesterday, things went a bit haywire.  Anyway, nothing some sanding, more paint and several good enoughs wont fix.   On another topic, I'm trying to remodel  my Whelen strobe/position lights.  I got some LED replacement red and green bulbs for the position light part, and they seem good.  To replace the heavy power box, I decided to try to go with a type of LED strobe light.  I bought these fog light LED bulbs and man are they bright.  Like hurt your eyes in very short order bright.  I bought some LED turn signal flashers that I planned to make the fog lights flash on and off with.  Got everything together and mounted today.  They seem to work real good.  Hopefully I don't get a ton of radio interference to go along with it.  Here are a few pictures, and a short utube video I put up.  JImChuk  https://www.youtube.com/watch?v=TYRQgkg1Wls
nice and bright.
I tried the radio this morning, and with nothing running except for the lights, I didn't hear anything for interference.  Hopefully that will continue.  I had the whelen lights already, but the remodel cost about $75 or $80 with $50 of that being the red and green position lights.  Got them on amazon for a good bit less then Aircraft Spruce.  Free shipping to.  JImChuk
The journey continues (sometimes I wonder if there is and end to it  :-)  Installed painted cowl today, and it all fits even.  Made a little access door for the oil tank that I'm pretty happy with.  Would have been hard to hinge it with the shape of the cowl, but this should work good I hope.  The list of to do things is getting shorter for sure.  JImChuk
5 people like this
Sure looks nice
Yes it does look nice.
Great idea for the oil inspection door. Removing the entire upper cowl is a pita.
Pretty quiet, and maybe this will inspire others.  Getting closer.  Also, here is the view over the nose with the tail up in the air.  I'm about 5'9" at best, and the camera was right at my eye level looking straight ahead in the picture of the view over the nose.  I'm going to like this set up for visibility.  That was my biggest gripe about the Kitfox round cowl.   My instrument panel is about 1 1/2" lower then the standard Kitfox panel.   I'm going to like it I think.  Got the tail feathers installed, and am setting diehedrial and washout.   This Kitfox had bare lift struts, (no streamlining)  I'm using the un streamlined lift struts from my other Kitfox 4 project so I can get this flying sooner, and then I can make up the streamlining for this planes struts at my leisure.  JImChuk
Sure looks nice
Thanks Jim for all the pictures. Install the prop tomorrow, W & B, and Test the engine. Getting close. Neil Rupp
Closer.... Labeled and lit up.  Old glare shield wouldn't work with new panel and cowl, so made a new one of those also.  Used part of an old lexan windshield for a form.  Worked fine.  It's painted flat black now.  The list is getting shorter.  Should be done by the week end.   (how many times have I said that already....)  JImChuk
Cant wait to hear a flight report.
Me to,  and a first flight video.  Soon, I'm hoping.  Hope my AnP isn't to busy and makes me wait for the conditional once I am done.  I'm thinking I will do a short walk around video once I drag it out for taxi tests.   I'll post that once I have it.  JImChuk
No first flight video, but how about a first taxi?  Poor quality, cellphone, and light fading.  Had the cowl and turtle deck off, but that's hard to see.  I do know when you hit the throttle, it sets you back in the seat.  And that's with an 80 HP 912.  Can't image what it feels like with the edge performance or something out of this world like that.  Well I'm happy for sure.  Engine hadn't run in a month, and it turned over half a revolution and was running.  Pretty smooth as well.  JImChuk
https://www.youtube.com/watch?v=CCw_dB63YL0
5 people like this
Well here it is right after doing the CG weighing.  Was hoping to come in under 650, and it ended up at 651.5 lbs.  As I was putzing around there a bit later, I noticed a shop light was hanging in the plane.  Removed that, an low and behold, it weighs 649.8.   Empty weight CG is at 13.46.  Still doing some calculations on rearmost CG, and at 1200 lbs the CG ends up about 14.9, which is .2" to far back.  My battery is about 3' behind the seat, so maybe I have to move it forward.  Or throw it out and go with a lithium battery.  One I have is a lawn tractor battery.  Cheap and works, but not real light.  What are others using for their battery on a 912, and what does it weigh?  JImChuk
Looken good Jim now all it needs is a $10000 dollar landing gear ha jk. I hope you get some nice cool mornings for test flying.
