218 posts in this topic
Looks Good TJay - easy to spot in the sky or in the snow.   EDMO
And time to start over
Wow!  looking good.  I see you have a prop there as well.  Is it for the Jabiru?   Jim Chuk
No that's a 60/44 Tennessee It was the take off from my challenger when I switched it to warp. It needs to get hung on the wall but you know how it works, I did love that prop it out performed the Warp in all areas
What paint did you use on the fuselage? I like the black, very clean looking.
This is the stuff that I used, I chose it because I painted the bucket on our 257B Cat last spring, we put about 30hrs on it this past summer moving dirt and lots of sand and the paint still looks great in the bucket, this stuff is tough.
Finally got a few more parts painted, So I can start to reassemble,
Nice work.  Very sharp!
Got most of the controls back in and finished welding up the rudder pedals, wrapped a strap under the torque tubes and welded a strap on the back side of the rudder cable attach,  Haven't decided what I will do with the brake pedals yet that's why there not finished.
got a little bit done over the weekend, Figured out where my rudder cables will exit the fabric, installed my header tank, and tonight I mocked up my baggage compartment, think I am ready to take it out and sew it up.
Even painted the header tank!? That's something I've never seen.
That will be a huge baggage compartment.  I'm wondering how you plan to get the stuff out of it?  When I first looked at the pics, I envisioned a second extended turtle deck that is hinged at the front end so as to have access to the compartment.  Would probably have to weld in a few pieces of steel for female cam lock ends like on the back end of the regular turtle deck.  Jim Chuk
Nah just through the opening under the turtle deck, it is set up to hold a small chair and my tent ha an maybe a 12 pack. I would guess 20 lbs,
I have to get in there with a small paint brush and get those Adel clamps sometime, There driving me nuts looking at them. Also epoxied and riveted in my flaperon Bearings, need to paint that epoxy too.
Not trying to tell you what to do, just thinking out loud. :-)  I'm looking at the middle picture of your last set of posted pictures.  Looking down on the top of the baggage compartment.  A flip up "trunk" lid hinged right behind the turtle deck would make access much easier.  Pulling off the turtle deck is a little bit of a pain, especially if you have an antenna mounted in it like my MK IV has.  This is also how airplanes get heavier and heavier though.  Lots of good ideas, and they all add weight.  Jim Chuk
My buddies kitfox has a hinged lid so you can get to the baggage area real easy.. its a great spot for rain water to get in and fill the fuse as well.  I am not too keen on having a hinge line on the turtle deck unless you plan on hangaring your plane.  Just my .02... and thats not even enough to put a down payment on a pack of gum :lol:
I think you will be surprised at how much weight you can get in that cargo area.. I have routinely put in.. umm.. A LOT.  If you can still lift the tail by the handles your good to go, just be ready to hold a little forward stick if you dont have a trim system :lmao:
Hey Leni, your right about water getting into the hinge area.  I thought about having a piece of flexable rubber that would go under the turtle deck, and over the hinge.  That would allow it to shed  water I would think.  Jim Chuk
I thought about doing that was well.  The hinge is nice, but you do need to do something about water intrusion.  Something about taking off on floats and as soon as you break water and pull the nose up you have about 15 gallons of water run into the tail... does not make for a good flight.  My buddy almost quit flying because that one scared him so bad.
Had a good Saturday here.
One word.  Duct Tape.  :blink:
Ha I have a Jabiru, that means I need the 200mph Duct tape.
Anyone know where I can buy stainless tape, and how thick it is?    EDMO
Thanks Jim - I was looking for some about .015" thick.  I may have to glue some aluminum on my tubes for shims.    I will keep looking.   EDMO
Tail is covered
