Avid Flyer Tyre Pressure
3 posts in this topic
My Avid Flyer is shod with Armstrong 8.00-6 4 ply tyres. It says that the maximum pressure is 24 psi. What pressures do you typically use and what would you recommend? I am sure that one must keep below the maximum pressure. Thanks.
I've got no first hand experience with the tires you have, but know that on our Aeronca Chief, with 600/6 tires, it would get more bouncy with more than about 12-14 lbs of air pressure.  I'm sure the Chief was heavier than your Avid.   I would expect you would have the same results with maximum pressure.  JImChuk
Those are old tires - Armstrong has been out of business for a long time.  Someone bought them, and I have the exact same tires with the new name, but can't remember it.  Anyway, when I got mine, I foolishly put the max psi - bad idea, it makes an already difficult ground handling airplane really squirrely!  I think I found in the Avid build manual that 8lbs is the desired air pressure.
