Posted 26 Nov 2015 I posted this on the Yahoo forum, but I did not get any takers;I have two short-wing Avids. One is a speedwing, and the other is apparently a clipped STOL wing. Both are 106 inches long at the spar.Both have 1 1/2 inch washout at the tip rib.I am not impressed with the flying characteristics of either one. I have a wing extension kit that was intended to extend a speedwing.Would I be better served by extending the speedwing, or the clipped STOL wing? Ribs are not a problem, I can make ribs.What is the experience with extended speedwings? Is it worth the effort.Thanks, Bob Share this post Link to post Share on other sites
Posted 26 Nov 2015 (edited) I have extended (aerobatic) speedwings with vortex generators. I enjoy the way the plane flies. Have a look at a video I made two days ago, messing around at my home field. You can see how the wings are extended out past the flapperons.Full disclosure: I'm a new pilot with ~50 hours and experience in only a handful of planes. Edited 26 Nov 2015 by Knuckledragger Share this post Link to post Share on other sites
Posted 27 Nov 2015 (edited) I have an extended aerobatic speedwing that was built to plans as far as the washout and I'm not all that impressed with it's capabilities. I didn't extend the flaperons but added an extension tube to move them out 3 feet away from the fuse. I'm sure if the wing was built with less washout it would perform a lot better. This Avid is fairly heavy at 667# 912ULS. VX 65 VY 75 and VS clean 48 I've never flown a STOL wing so I cant compare the two I know not much help so we'll just call it 1 cent worth Edited 27 Nov 2015 by birddog486 Share this post Link to post Share on other sites
Posted 27 Nov 2015 I have extended (aerobatic) speedwings with vortex generators. I enjoy the way the plane flies. Have a look at a video I made two days ago, messing around at my home field. You can see how the wings are extended out past the flapperons.Full disclosure: I'm a new pilot with ~50 hours and experience in only a handful of planes. Good video - But, I couldn't tell if you are making use of the flaps on TO & Ldgs - It would make a difference.EDMO Share this post Link to post Share on other sites
Posted 27 Nov 2015 No flap use during this video. What specific "difference' are you referring to? Good video - But, I couldn't tell if you are making use of the flaps on TO & Ldgs - It would make a difference.EDMO Share this post Link to post Share on other sites
Posted 27 Nov 2015 You can get in and out shorter using the flaps. I have some time in and extended speed wing, but it was built that way. I think if you extend a wing with 1 1/2" of wash in it already its not going to help too much. I would try to take some out of it when I did the extension. Share this post Link to post Share on other sites
Posted 28 Nov 2015 (edited) You can get in and out shorter using the flaps. I have some time in and extended speed wing, but it was built that way. I think if you extend a wing with 1 1/2" of wash in it already its not going to help too much. I would try to take some out of it when I did the extension.My Kitfox wings are 160" not counting the tips, which can vary from 12 to 18" more on each wing. I modified my "STOL" Eppler undercamber ribs to a modified Kitfox Riblett profile for better cruise, but built them originally with 1 1/2" washout, and wish it had been 1/2" - have not flown it yet.EDMO Edited 28 Nov 2015 by EDMO Share this post Link to post Share on other sites
