Repair of fuselage lower aft stringer
9 posts in this topic
I broke the stringer under the tail of my Flyer. The description of how I managed to do this is posted in my "Yup, I did a Dumb" thread.  This is documentation of how I repaired the damage.
There are a lot of pictures of the process I went through to accomplish the repair.
First I removed the damaged fabric just enough to see what I was going to have to do. then I removed the broken wood stringer pieces.  I made a new stringer section and used epoxy to attach some wood doublers to each end of the replacement strip.
post-1147-0-84749500-1442079084_thumb.jp post-1147-0-31957400-1442077676_thumb.jp post-1147-0-57277100-1442077687_thumb.jppost-1147-0-76454200-1442077854_thumb.jp
I had to open the fabric up some more to be able to clamp the replacement section in place while the epoxy set up.  The holes ended up being a bit larger than I had originally hoped they would be.
post-1147-0-34940400-1442077962_thumb.jppost-1147-0-97162400-1442077969_thumb.jppost-1147-0-59761300-1442077978_thumb.jppost-1147-0-59706100-1442077987_thumb.jppost-1147-0-64055100-1442077995_thumb.jp
After removing the clamps and a little sanding I removed the paint around the edge of the holes in the fabric with MEK to be able to bond the replacement fabric to the original fabric.
post-1147-0-24888300-1442078003_thumb.jppost-1147-0-37442000-1442078011_thumb.jp
I glued on new fabric with POLY-TACK fabric cement.  After the cement dried the new fabric was ironed to draw it   tight.
post-1147-0-95201200-1442078019_thumb.jppost-1147-0-19330400-1442077953_thumb.jp
After ironing the fabric tight POLY-BRUSH was applied and finishing tapes were applied to all edges of the repair.
post-1147-0-74281800-1442078213_thumb.jppost-1147-0-80487800-1442078221_thumb.jppost-1147-0-13114200-1442078206_thumb.jp
More POLY-BRUSH over tapes to fill the weave then 2 coats sprayed on.  Two coats of POLY-SPRAY (silver for UV protection) after the POLY-BRUSH had flashed off.  Wet sanded then added two more coats.
post-1147-0-89170700-1442078482_thumb.jppost-1147-0-91485900-1442078472_thumb.jp
After the POLY-SPRAY had dried enough the repair was painted with two coats of POLY -TONE 105 White.  The original fabric and paint was applied in 2000, 15 years ago, still looks good and is repairable.
post-1147-0-11512100-1442078697_thumb.jppost-1147-0-79664400-1442078687_thumb.jp
This is why I personally like the POLY-FIBER process.  The repair was fairly simple and the only really difficult part was working over my head laying on the trailer.  While I was at it I added another inspection ring so I can get to the elevator push-pull rod bushings buried in the aft portion of the fuselage for lubrication and inspections.
MarkD
Kudos to you, Mark. Way to get on a repair! I can sure see the merits of a polytone finish. With Aerothane, I'd still be thinkink about how to blend it in (though not as much on the bottom of the fuse).
Great job to make the oops go away!
I'll second the emotion on the ease of Poly Fiber repairs, especially with 'tone paint.
Really nice work!
I wasn't around when my buddy repaired the J3 wing, but he said it was very easy to repair the fabric with Stewarts finish. He has done other finish repairs before. I could ask him for more details if anyone wants to know.
Did you have some poly fiber materials laying around or did you buy a repair kit? I have a few small things I'd like to do to mine but I have zero usuable covering supplies leftover and buying even the smallest available is still spendy!
What exactly do you need Joey, I have lots of polyfibre stuff, and lots of stuff to cover, but might be able to send something your way. Jim Chuk
Joey,
I had some material left over from a recent RANs S-6S I built for my Father-In-Law.  I usually try to keep some material on hand just in case for situations like this.  I will end up ordering a bit more to replenish what I used this time though.  I order the liquids a quart at a time except for the reducer (always get a gallon of reducer).  If I'm in a hurry I can get it at one of the local airports here but it sure is a lot more than ordering from Spruce.
MarkD
Thanks for the write-up and photos.
Pretty much reinforces my thinking about the repair I need to make to my rudder fabric.
Lou
