Avid STOL and Heavy Hauler rib sketch.
4 posts in this topic
I traced out a rib on 5 pieces of copier paper that were taped to a table,  Also will try to post a few pictures showing the exact length of the rib.  That way if you copy and print off the sketches and tape them back together, you can double check if yours are the right length.  If your printer isn't printing full scale, it could be wrong size.  JImChuk
PS  not sure if this will work if you copy the images and then print them out.  If someone tries, let me know how it worked.
Jim i copied and joined them but they are really light ill try to take it to office depot and darken it up if possible, Thank you
If it doesn't work out, I could copy them on my printer, and mail them to you.  JImChuk
Hi Jim. I switched to MS edge instead of my usual FireFox. Now I can answer posts. I couldn't get anything to type before.
IF you are mailing them out. Can you mail the traces directly with copying? THAT way we KNOW there is no size distortion.
I'll try again to send you a PM.
THANKS
Keith
