Rigging
1 post in this topic
Pulled the Fox out today and rigged the wings. Washout was the same on both wings. Will have to re-run the fuel lines due to the flapperons folding and hitting them.  Big problem was that I found one of the false ribs broken loose. I guess it was so hot today it either tightened the fabric too tight or got the epoxy soft enough that the fabric pulled it loose, whatever the cause, have to remove the fabric around the rib and redo it. Which requires repainting that section. About had it with this rebuild. Don't be surprised if you see it on barnstormers for sale. Then back to the two part kit.
