Posted 27 Aug 2017 I have 2 sets of tail springs for the Avid. I also have a aluminum spring gear (Grove) which may need to be straightened somewhat. IDK for sure. Will sell all at very reasonable offers. larry Share this post Link to post Share on other sites
Posted 27 Aug 2017 Are they 1 1/2" or 1 1/4" wide? JImChuk Share this post Link to post Share on other sites
Posted 28 Aug 2017 If Jim doesn't get the tail springs I might be interested. Howbout some pictures? Thanks Share this post Link to post Share on other sites
Posted 28 Aug 2017 (edited) How about more info on Grove spring gear? Photo & price too? EDMO Edited 28 Aug 2017 by EDMO Share this post Link to post Share on other sites
Posted 28 Aug 2017 (edited) Hello Larry,Sounds like a bad day may have involved - sorry to hear if that's the case. I'm interested in the Grove gear and a 1 1/2 " tail spring. What's the best way to contact you? My phone is 2one8 3nine1 1844. Edited 28 Aug 2017 by marcusofcotton Share this post Link to post Share on other sites
Posted 28 Aug 2017 If Jim doesn't get the tail springs I might be interested. Howbout some pictures? ThanksI'm not really interested in the tail springs, I was just trying to clarify what Avids they would fit for others. Avid MK IV used an 1 1/2" wide one earlier models were 1 1/4" wide. 1 person likes this Share this post Link to post Share on other sites
Posted 28 Aug 2017 (edited) If Jim doesn't get the tail springs I might be interested. Howbout some pictures? ThanksI'm not really interested in the tail springs, I was just trying to clarify what Avids they would fit for others. Avid MK IV used an 1 1/2" wide one earlier models were 1 1/4" wide. Same here on the Grove Spring Gear - What model is it for and how badly bent is it and what price, and does that include attachment parts. If it is old type 2024 aluminum it can cost as much as a new 7075 spring to have Robby straighten and re heat treat it. The serial number should be stamped on the front of it in center. EDMO Edited 28 Aug 2017 by EDMO 1 person likes this Share this post Link to post Share on other sites
Posted 28 Aug 2017 Thank you for all the responses. I will try to get all the info posted this morning. I am not postive that the Grove is bent. My tail broke several years ago, and the insurance company fixed it. I want to use the "bush gear", so we went that route. I will look it over real good and report back. Unfortunately, the repair facility threw out the mount brackets! Double upset! I am just about to leave the house for 2 days, but will get details asap. Mean time, you can email me LJ@nitrams.net I also have axles 3/4" bolt ons. Details to follow. Share this post Link to post Share on other sites
Posted 30 Aug 2017 The tail springs are 11/2", one set has been used, the other set is new.The main gear (Grove) is probably 2024. I don't think it is bent. I will check this week. Pictures should be available this week too... Share this post Link to post Share on other sites
Posted 30 Aug 2017 (edited) The tail springs are 11/2", one set has been used, the other set is new.The main gear (Grove) is probably 2024. I don't think it is bent. I will check this week. Pictures should be available this week too...Just for info - Grove gear for Kitfox Taildragger is 22" axle to top of spring - Tri-gear spring is 16" - Imagine Avid is about the same except maybe a few inches narrower on the span. These gears were made for different models and gross weights too. Grove catalog gives specs. Unless 7075 is stamped on it with serial number it is 2024 aluminum. I have the 22" Kitfox 5+ 7075 and it gives me a little more height with my tri-gear, wider mains, and 1550 max landing weight on my beefed-up fuselage. EDMO Edited 30 Aug 2017 by EDMO 1 person likes this Share this post Link to post Share on other sites
Posted 1 Sep 2017 (edited) Here are the pics of the gear, axles, tail springs. I have 2 sets of springs. I don't recall how I got them... one set I did not use and is from Brett. In the rebuild I wanted his bush gear and a tapered tail spring like I had one the Skybolt. These have been sitting around for a few years. I am not sure if the main gear is tweaked or not. It shouldn't be. I was going to sell it years ago, then got discouraged when I didn't get the mounts back. (that was also during the fall of the economy and all) Anyway, the gear is available. I have a freind with a very good eye for detail who will look it over carefully. I will post more picires at that time. The axles are for the Grove gear, and also a set for the tubular gear.You can contact me directly at LJ@nitrams.net Thanks Edited 1 Sep 2017 by larryMar additional info Share this post Link to post Share on other sites
Posted 1 Sep 2017 I'm interested in a tail spring. How much for one? Thanks, Bryce Share this post Link to post Share on other sites
Posted 1 Sep 2017 Here are two pics showing different dimentions for Avid aluminum gear. Which one is yours? Also, can you post some pictures showing the entire landing gear? Thanks, JImChuk Share this post Link to post Share on other sites
Posted 4 Sep 2017 At this time, everything is sold. If anyone chooses not to purchase, I will repost at a latter date. Thanks,larry Share this post Link to post Share on other sites
