CONNECTING BOWDEN CABLE HOUSINGS?
14 posts in this topic
I think most everyone knows what a Bowden cable housing is -
My question: If you want the housing, not the wire, as two pieces joined together, how do you join them?
I am thinking about making my trim cable in two pieces for easier assembly of the elevator to the fuselage.
Hi Ed, I imagine a piece of tube that the cables fits snug into would line them up so they would work as one cable. the question then it how do you keep them from sliding out of the tube? First thought is a hole drilled near each end of the tube, a small nut welded over the hole, and then a screw is tightened into the nut which would put pressure on the cable to keep it from moving. That's a "first" thought though, and I haven't finished my first cup of coffee yet this morning... It's funny that you bring up the Bowden cable topic. Just last night I was looking on the web to see where I could buy a new Bowden cable for my Avid rebuild. Couldn't find any. Who has it? My trim cable is about 15' long. Jim Chuk
Jim
Spruce has the Bowden cable - probably Wicks, Wag, and others. I thought about a rubber or plastic tube or clamp to keep the housing ends lined up - a clamp near each end should keep them from spreading apart - of course, there are many clamps all thru the length of the housing to keep it from moving.
I didn't know if anyone makes a connector just for the housings.
There are two sizes of cable / wire - I think the heavier wire is .078, but haven't looked for a while, and only on 2nd cup of coffee. Going back to bed - only slept 4 hours.
Confused here Ed. Are you trying to secure two cables running parallel to each other for redundancy if one breaks or something?
Doug,
I want the housing to be in two parts in series for easier assembly (one continuous wire)
Why?
To make tail assembly easier and to keep from running cable outside of elevator and to keep from hiring midget to thread it thru the fuselage?
Once the elevator is covered, there is no way to run the cable housing thru it and clamp it on the inside.
Run and secure it before covering. My plane looks like a spilled bowl of spaghetti right now.
If it's really absolute that there needs to be a joint, you'll have to use something like a bellcrank or something to terminate one cable and start the next...
Hi Ed, I think you wanted to see pictures of how my trim cable was run, so I got a couple for you yesterday. Didn't have the elevator handy, but the cable is outside the fabric on the elevator where it goes to the trim tab. I'm sure there is a bit of drag from that, but it's easy to thread the cable through the holders. Enjoy, Jim Chuk
Edited by Jim Chuk
Thanx for the photos Jim,
I was wondering about clamping an aluminum tube inside the fuselage and running my cable thru that - My elevator / HS set a lot lower than your Avid. Running the cable outside of the elevator looks like the easiest too for replacement.
I thought drag was a good thing - helps you get stopped quicker!
Funny you should mention an aluminum tube, that's what I'm thinking about for a conduit for my battery cables and any other wires going back to the tail area. I'm trying to remember what I told TJay about if it falls to the floor if you let go of a not absolutely essential part, don't put it in..... Right now I'm thinking about taking an 8' long florescent light bulb, and wrapping it with a layer of fiberglass, then slitting the fiberglass after it hardens up to get it off the tube, then patching the cut. Hard to get much lighter than that with what I have on hand..... This is going to be a long project, and it will still end up too heavy! Some times I let my mind wander way to far without adult supervision. Jim Chuk
Jim,
I've done a lot of fiberglas work - I wouldn't use a light tube - had too much fg stick to mold - a thin electrical conduit or PVC pipe would be safer to use. Wouldn't want glass particles stuck to fg..Put 3 times as much wax on the mold as you think you need.
There used to be fg tubes you could buy - forget where...
My mind wondered off in a different direction, I'm thinking I will use a piece of 1/2" pvc or aluminum pipe, tie the battery cables to the outside of it, and use it for a conduit for tail light wire and if I ever put electric trim on I can snake those wires down inside the tube. I want the battery cables supported better than just tieing them to the cross tubes where they will drape down onto the fabric between the tubes. Jim Chuk
Plastic is better - aluminum or steel cause shorts! Thinwall PVC probably don't weigh much more than fiberglass,
ED
