MAGNUM WING STRUT ATTACH BRACKETS
7 posts in this topic
Leni and Bob,
Just a reminder that when you build new wings, the Magnum has 8 more rivets in each bracket. Doug and I have the drawings.
I am not building a magnum wing, its just going to be a HH wing with KF IV ribs.
The reason I quoted that is my theory of "more is better" - If they put 8 more rivets in the same bracket as the lighter planes, then why not spend a few dimes and go for more strength in the setup?
good point Ed!
Leni and Bob,
Hi Ed,
Since my fat Avid is pretty fat, I plan to build my new wings with a few tweaks to increase the load safgety factor in them.  Can you post the drawings?
Thanks.
Hi Ed,
Thanks.
I thought I had postd them before, but maybe just sent them to someone.
I will post asap - but with my puter Xpertese, that may take a day or so.
Mostly, it tells you to draw X's between the top and bottom center rivets on each side, 8 lines will give you 4
X's, and the middle of each X is where you put the new rivets - 4 SS rivets on each side of bracket.
Hope that can be understood.
JOEY, LENI, BOB,
I posted the pdf photo in the Magnum Section.
