AVID Flyer STOL With Floats & Skids
3 posts in this topic
Just for my information, what do you think my plane is worth.  I have a 1988 kit completed in 2013.  Certificate of airworthiness, original fiberglass and gelcoat floats, skis, wide gear with 21" tires, Garmin 296, mgl avionics instruments. Also have the original factory cargo pod.  It has the HH struts and mark IV cowl.  Rotax 582 with 58 total hours.  The plane and motor have a total time of 58 hrs.
Thanks for your input.
Edited by AVID STOL HH
you can look around and see what they are going for on Barnstormers etc.  I think you would be hard pressed to get much, if any over 20 on it.
Mid to high teens probably. The floats and skis should add some value if you find a buyer that wants it all.
