PROP BOLT CIRCLE DIMENSIONS?
9 posts in this topic
Can anyone give me the center to center, bolt circle diameters for the 912 and 582?
I have also verified that the small Contental is 4 1/2 " bolt circle diameter - I think some Tomahawk 235? Lycomings also used this SAE-1 bolt pattern.
My SAE-2, Lycoming style, bolt circle is 4 3/4".  I know that there are SAE-3,4,5, etc. that are larger patterns or bolts.
Just trying to update my library.
Thanks,  EdMO
912 is a 75mm bolt circle.
Sprecken Ze American, Larry?  Is that 4" or 4 1/4"?  No, I guess 75 sillymeters is about 3 inches?
I wonder what fits a 4 1/4" bolt circle, could that be for Jab or UL, or Something else?
There is a WD hub on ebay with that circle dimension, along with a smaller circle that is probably Rotax.
I don't need it - Just being nosey!
75mm = 2.953 inches
My 582 6 bolts @ 1.5" o.c. OR 38.1mm o.c. & still 6 bolts
Edited by KFfan
Ed, the small Continentals and Lycomings were 4 3/8 inch bolt circle.  the small Franklins had a 4 inch bolt circle.
Thanks for the info - I asked a guy to measure a C-65 or O-200 flange and he came up with 4 1/2 center-to-center diameter for Continental, but maybe his yardstick was off a little.   We need more Franklins around!
I found a chart of sorts that is on the web.  Here's the link:  http://www.aviationbanter.com/showthread.php?t=2659
Hey, that's real nice - answered a couple of my questions about my flange.  I made a print of it for my files.
I still haven't figured out what takes a 4 1/4" diameter 6 bolt hub...Maybe its actually something in sillymeters?
