BEARING ENGINEERING QUESTION
5 posts in this topic
Bearings for nosewheel pivot shaft:  Which would have the greater friction - 2 inches of brass bushing, or 4 inches of PVC?  Weight and Wear and Cost are not a consideration, since the nosewheel pivot gets less use than the PVC bearings for flaperon hangers.
A brass bushing will gall against steel and have a very high coefficient of friction.  You are probably thinking of a bronze bushing (tin-copper as opposed to zinc-copper alloy).
The Bronze will be more impact tolerant than the PVC (softer material) and will last longer at a resistance tightness.
(yes I am an engineer and yes I used to work for a bearing company.   :lam:   )
I understand exactly what you are saying - I meant bronze - actually would prefer OilLite - Sure hope for no IMPACTS!
Thanks for the info.
Just normal landing and taxiing operations will be impact enough to deform a PVC bushing, IMO.
OilLite would be your best option for durability and smooth operation.
I ordered two OilLite SAE-841 Oil Impregnated bronze bearings today.
Thanks again,
