DAR Inspectors
2 posts in this topic
Getting ready to apply for Air Worthiness Cert. Do any Alaska residents have experience with either Rod Russel or Greg Monette and which one is the easiest to work with.
Thanks for your input.
Most DAR's are easier to work with than the FAA. His time is precious. Make sure you have everything in order. Have the cowl off and the seat off. Be ready to explain your Weight and Balance and any other questions he might have. If you come across as prepared and knowledgeable it will go a long ways. Good luck!
