Avid Heavy Hauler Project for Sale
3 posts in this topic
Avid Model C , original build in 1994.
I purchased this aircraft complete. It was sitting in the back corner of a hangar for quite some time untouched and covered in dust. We disassembled it completely down to the bare fuselage to rebuild fresh. FAA Registration has been updated and is current with original N-number and data plate. Fresh Rotax Rick 582 overhaul with 612 Rave upgrade and new custom RAVE exhaust. Complete logs since build, along with builder logs and original build documentation. No damage history. Original panel and instruments. Last few photos in Red are original as I purchased before disassembling for rebuild.
Fuselage:
  1. Stripped, inspected, and powder coated blue
  2. All steel components also stripped, inspected, and powder coated (ready to reassemble)
  3. Covered using Poly-Fiber through paint (Poly-Tone Eagle Blue)
  4. Grove spring gear currently mounted on fuselage. (have original bungee gear as well)
  5. Refurbished & re-lined Grove Brakes and new Aero Classic 8.00-6 tires.
  6. Horizontal Stab & elevator covered using Poly-Fiber through paint  (Poly-Tone Glacier White)
  7. Rudder powder coated and ready to cover
Wings:
  1. Heavy Hauler wings (fabric removed, still need some work before recovering).
  2. Two new fiberglass wing tanks (yet to be installed).
  3. Trailing edge aluminum to replace cable trailing edge (yet to be installed)
  4. Poly-fiber fabric to cover.
Fantastic rebuild project with lots of work already completed. Work done is meticulous and has been periodically inspected by A&P along the way. Most of the remaining work is refinishing and recover of the wings, assembly of control linkages, rigging, installation of engine and instruments. I also have all original glass and firewall to use as patterns.
I just don't have time to dedicate to this project. Would much rather see it go to someone to finish it!
Located at KGRB, near Green Bay, WI
Asking $22,000
Edited by 7ecaflyer
Posting pictures is always helpful in an add.  The more the merrier.... JImChuk
Thanks!
Taking some later today to add.
