looking for avid mark IV condition inspection checklist
3 posts in this topic
Buying a mark IV with 582. Looking for a condition inspection checklist I can go over with my A&P.
Alan
Edited by amekler
misspelled
If he has the builder's manual for the plane, there is probably one there near the back of the book.  I can probably find one for you if the manual doesn't have it.  I am having trouble scanning things right now though for some reason.  Just thought about it also, there is likely one in the files and forms section.  There is a complete build manual there.  JImChuk
PS, just did a quick search in the archives and found a link to one.  Condition inspection time..582 checklist? - Avidfoxflyers General Hangar - AvidFoxFlyers Forums
look at the fifth post for a pdf file that you can download
The Avid condition inspection checklists I have seen are pretty simplistic. I have found the Kitfox checklist(s) to be much more comprehensive. Grab one online and look it over. You might have to search around a bit but they're out there. Not everything in the KF checklist will apply. you should be able to go through it before you look at the plane and determine this things and just mark N/A or cross them out. This will give you a good comprehensive list.
On the other hand, since you are doing with an A&P, Maybe you want to use as brief a list as possible :-) depending on your objective for the inspection.
As far as the engine is concerned, Rotax has a table of inspection points for the 582 based on time ....every flight, 25 hours, 50 hours and so forth. Wouldn't hurt to grab one of those on line and print it out too. You can use whatever schedule on the chart seems appropriate for the inspection. It will certainly help you not to miss things..
You will like the Avid.
Edited by ChrisBolkan
