Help identifying ribs
5 posts in this topic
Newbie here, with a ton of questions and don't really know where to begin. I have just acquired a new to me Magnum project. Well, just a couple set of wings at the moment. I have spent a lot of time reading through the forum and have came to a few conclusions, but I need help. Both sets of wings are no good as they sit and need to be rebuilt. Starting with just 1 set for now, I have questions and concerns.
1. The shape of the ribs don't seem right, they are not flat and definitely not an under camber as you can tell in the pics
2. With the "convex" shape, the jury strut mounts and lift strut mount are essentially flush with the fabric
3. At 108" the spars are extended (very poor construction), The front spar extension is installed fairly straight, but the rear spar angles several degrees downward and has about a 1 1/2" drop over the last 2'. I did not capture this to show you but it is very twisted at the end and I have never seen anything like it.
My first and most important question is can these reasonably be rebuilt? I know that is a generic question, but that is the question I am after. These wings started life I believe as HH's because the wall thickness is .083" and rib placement is 12" apart. What concerns me is the 108" length where the splice begins. Can I cut there and rebuilt past that point? I have called around trying to find .083" tube and all I can find is .065" and .125". Next is the rib, the general consensus I am reading is that the under camber design is more desirable? The second set of wings I have do seem to have the correct rib profile, but the spars are .065" with 18" spacing.
I can either laser cut or CNC new ribs, as I have all the equipment to do this and more. I think the easiest and best bet would be to start with new spars, but I cannot find .083" wall material. I've even thought about just stepping up to .125" which was an increase of about 6lbs per wing if I remember correctly. I know this is a big can of worms, but I needed to start somewhere and introduce myself so I figured why not this way. I'm really excited to go down this very frustrating and painful road so be easy on me to start! Thoughts?
Russ
Welcome to the group Russ.  Those ribs don't look at all like Avid ribs that I've seen.  If it was me, I think I would plan on building new wings.  Kitfox uses .065" spars on their Kitfoxes that go up to 1550 gross weight.  They also have a nice 5' long stiffener that goes in the spar.  Avid stiffeners are much smaller.  Actually, Just Aircraft uses the same stiffeners as Kitfox.  Depending where you are located, they may be closer to you.  I was going to buy some spars and stiffeners a few years ago, and Just was actually a bit cheaper than Kitfox.  Not sure about now.  JImChuk
Isn't that an Avid Speedwing airfoil?
At last I heard, Kitfox will not sell you spar stiffener inserts without a Kitfox serial number.
Just will.
Thanks Jim, I have a feeling I'll be looking to you quite a bit as I see you are very active and knowledgeable. I indeed plan on building new but my concern is just what you mentioned. The .065" spars are for 1550 gross, I'm looking to take advantage of the higher gross of the Magnum. Are the .065" rated to 1550 gross with or without the stiffeners? I have a Magnum manual, but it doesn't have specifics, or at least what I am looking for. All I know is that the magnum ran .083" spars for a gross of 1,750. I'll have to look again, but I believe it shows wood stiffeners as well. Is there a vendor that currently sells 12' sticks of .083" tube? What about going to .125" wall since that is readily available? Thank you
Just will.
After doing some more searching I have found others with this same profile, and they have called it the speedwing. I will be visiting Kitfox in just over a week and will talk to them then, but in the meantime, I will call Just Aircraft tomorrow. Thanks for the help
