adjusting flaperons with the F7a mod
6 posts in this topic
Are the Flaperons with the F7a bellcranks adjusted the same as the standard bellcranks? Thanks, Neil
I don't think there would be any difference in how you adjust them.  The idea is that both sides go up and down the same amount.  What helps is to clamp a stick on to each flaperon pointing back.  18 -24" sticking out to the back, but same amount on both sides.  With the joystick all the way to one side, measure from end stick to floor on both sides.  Put joystick all the way over to other side, and measure sticks.  When it's set up right, both side measurements will be the same.  The longer the stick, the more obvious the difference will be from one side to the other, showing you when you are getting closer to the correct adjustment.   JImChuk
OK I understand now. I read the stick deal on other post but didn't understand what was going on. Thank you!! Neil
When the wings are level is the floor or the door sill suppose to be level also? Mine are not. Neil
I've never checked the floor against the wing.  Just leveled the wing and did the w&b.  JImChuk
Thank You, Neil
anything else i need to check or look out for?
thanks for the info guys
