I would like to stretch a Avid Fuselage.
3 posts in this topic
I would like to stretch an Avid fuselage. I have a spare O-200 and wonder what fuselage I could put it on.
Lighten up the 0-200 a few lbs and it opens up the canidates a bit. Only had 2 problems out of an 0-200 in years past and both due to pilot misuse. The exhaust valve on #4 cyl and heads cracking at the exhaust valve on the same cylinder. All due to pilots cut and dropping causing thermal shock to the front left cylinder. And yes, mostly on rental aircraft. Have never replaced one on a private owned aircraft due to this. Rental aircraft live a tough life.
Do a search for the Avid that Suberavid is doing on one of his to install i think he told me a 4stroke yammy motor.
