Adding dual brakes - Matco MC-1
12 posts in this topic
I want to add right seat brakes to our Avid MK4 which currently has MC-1 reservoir master cylinders for the left seat. Can anyone confirm whether it is okay to keep these when installing new non-reservoir master cylinders in series for the right seat. I've read somewhere about creating an unintentional parking brake function of both sides are used.. Are we better-off replacing the MC-1s?
Regards
Ad
There is a simple fix if you have some mechanical ability. Here is the matco SB on it.
http://www.matcomfg.com/ServicebulletinForMC1PressureLock-idv-2661-23.html
Any idea whether this mod is needed just for the old MC-1 and if so is it when using two sets of MC-1s with reservoirs? I'm still not sure whether it's okay to use an old MC-1 with a newer pair of cylinders for the right seat.
Ad
The tech guy at Matco (George is my memory is correct) is very nice to talk with.  I would suggest making a call to him.  He for sure can give you the correct answer.  JImChuk
We used the MC-1 on the pilot side and added non reservoir pair on the right side and they work just fine.  Like Jim said, give George a call at Matco and he will give you good info.
I used MC-1 on one side and non-reservoir MC-4A master cylinders on the other side. My MC-1's have the mod done and everything works great.
Thanks all, much appreciated
Sorry, digging up this old thread. I tried today to install dual brakes on my avid. I used two pairs of MC1 and it leaks on the top of the shafts!
The link to the service bulletin mentioned above does not work: would anybody have a copy of it?
if I make the mod, would it work with 2 MC1 in seriies or should I have one MC1 and one without reservoir as 109jb did?
thanks guy for your support!
As you found out using two sets of Mc1 does not work for dual brakes.
Thanks for the answer… but any good tip on how to make it work?
yes it does, thanks!
