FS IVOPROP Medium Adjustable
5 posts in this topic
IVOPROP Medium Adjustable DL258, 75 to 100 hp, 2 blade, 58" Dia, Flange is 4" Volkswagen. This prop is NEW, Never Used. Purchased in 2000. Cost today is $1000, Sell for $800 OBO
IMG_57081_zps30p9jzmc.jpgIMG_57091_zpsr6eqbz4z.jpgIMG_57121_zpserxugsxg.jpgIMG_57131_zpsq96q0qap.jpgIMG_57061_zpsnoulc3iw.jpg
Edited by OLDMNSX
VW means Left hand rotation?
My understanding is all VWs use a left hand prop.  This is a left hand prop.  JImChuk
not entirely true. Most VW engines in airplanes are left hand, but there are some that are right hand. Most VW aircraft engines drive the prop from the end that had the generator pulley in the car. The opposite rotation is accomplished by running the prop off of the flywheel end of the engine rather than the pulley end. Steve Wittman's V-Witt Formula V racer was built this way way way back when.  Great Plains also currently markets a VW engine conversion that drives the prop off the flywheel end.
OK guys, big surprises on this prop. Just got off the phone with IVOPROP.  The hub fits a Rotax 912 80 hp Ser 415 and up. Also, 912 ULS, 914 or 915. The blades WILL NOT work on the previous Rotax engines. The blades WOULD work on a Rotax 582 with a 3:1 ratio box. The hub doesn't fit the 582.
The blades would work on a KR2 with a Corvair engine.
MAKE ME AN OFFER
