AOA
13 posts in this topic
Anybody ever installed a AOA indicator on their Avid/Fox?  Most I've looked at install on the leading edge of the wing, which doesn't  work with our wing spar.
Most I've seen lately install like a pitot. Here are a couple examples, Garmin and Dynon.
Do u mean a BACON SAVER? Hahahaaa
I guess it could be called that!  Surprising that I haven't heard or seen anything in the Flying Cowboys videos about them. One could be an asset to a STOL pilot when trying to land as short as possible. But then what they call short could give some of us a chuckle. To me, short means its got a big H in the middle of it.
Edited by Allen Sutphin
I think Trent Palmer has one on his plane.  But then I've been wrong before.... even admitted it once:lmao:JImChuk
I've only been wrong twice, got the alimony canceled checks to prove it !!
Maybe you were wrong only once.  If you had figured out how to get along with the first one, the second one wouldn't have happened.  I think that makes the second one 'unintended consequences'.  Why am I not out working on my Kitfox?  JImChuk
With my build, I bought a Dwyer differential pressure gauge to use as a lift reserve indicator.  You add a second pitot tube angled down ~45 degrees and this gauge reads the difference between the pitot pressure and this tube.  Costs ~$50.  I am also working on a DIY glass screen that will have an electronic pressure sensor to give me the same info and could also sound an alarm but first I want to get the airplane flying...
I built one of these LRI and flew with it a while but found that it just wasn't for me.  Found that it was better to listen/feel the airplane and respond without distracting me from the job at hand. I still have it around somewhere and the patched hole in the panel to remind me:wacko: Your mileage my very.
I have an AOA in my plane.  It is an awesome addition to my flying and I believe an added safety measure.  I use the Dynon dual input pitot tube hooked to my D180.  This also outputs an audio warning into the intercom.
They might not be for everybody.
Here is a pic of the one i have, i bought an ivo pro from a guy this winter and he sent this with it as an extra.
