Broken springs
16 posts in this topic
I was having fun till my T/W spring broke, I hope the heim joints don't break again, I couldn't tell if it came down on the rudder or not but is was very very close:huh:
This kinda thing must happen somewhat often, but since the spring is broke is there a better replacement option, such as aluminum or something?
BTW aviation is such a great community, the airport my mishap happened at, the manager let me but the airplane in an empty hangar till I can get it fixed:BC:
single or dual leaf?  Can you get a good shot of the end of the spring at the break?
  Glad is did not end any worse!
Taller gear will help out with not smacking that tail wheel first all the time as well and will make you happier I think.
Its dual leaf spring, but it broke just after the top spring stops
I hear the T-3 is pretty cool also the grove spring or kitfox has a 3 leaf too.
Is your top spring square across the end or rounded, its kind of tough to tell from the angle of your pics.
The bend in it right at the front of the saddle looks like she has taken a beating.  How many hours are on that spring?  Sometimes when you beef up a sacrificial part, it makes you break other parts that are much more expensive and time consuming to replace.
Here's a pic before I installed the new tailwheel.
I would figure there's 500hrs on that spring, probably original if I had to guess.
I did do a tail first full stall landing but it's the next landing that it broke on,  that was a 3 point.
It looks like it's been cracked a while, just never noticed it cause its pinched on the top.
My landings are not bad at all and I land on decent grass runways, nothin off airport yet, still practicing
Since you changed tail wheel assy's, any possible issue with the new brackett extending less or more than the original bracket?
Edited by Allen Sutphin
The new T/W assy covers the same amount of spring, only thing is the new T/W is a couple pounds heavier:dunno:
I hate it when that happens!  You are not the first.
I broke my original on my MKIV and replaced it with a wider and thicker double spring. I never broke the spring but had the mounting bolt break on my Avid+ and dropped in on its rudder when I was just pushing it into a tiedown spot.  I finally put a T3 on mine, not cheap but it takes a lot of the beating off your whole tail assembly and is really nice to land with and taxi.
I love the T3 just wish they weren't so expensive or I would have one::)
I bout the 3 leaf one from Kitfox, hope it's good enough
I think a shorter (helper?) spring should be cut straight across or rounded, but not pointed like in the above photo. That would cause a stress point in the main spring.
Edited by Ronin
added photo
I used a dual spring from Wausau Springs, (715) 845-6335, at about $75. Nice guys, strong springs.
On my bluefox #0038 I used a stock univar supercub 3 leaf spring, but i left one spring out, so just used two, so far seams to work great, got it for $50 at a hanger cleaning sale. And it was curved correct for the tailwheel axle to sit right,
A few years ago, I bought a new Aeronca Chief spring, and the guy had a never used three leaf 1 1/2" wide experimental tailspring that he threw into the deal.  I think it came from aircraft spruce, for an Acro Sport if my memory is right.  When I needed a new spring for the Avid, I used 2 leaves from that spring, maybe rebent it a bit in my press.  I think they sold that spring for about 55 or 60, although when I just looked for it on their site, I didn't find it.  Works fine for me.  What I have found is if you want to make your own, you can find 1 3/4" wide springs pretty easy, seems that's the width used on light trailers often,  but the 1 1/2" or 1 1/4" width is harder to come up with. JImChuk
