B model back in action
3 posts in this topic
Well after longer than I wanted to spend on my cowl, stator swap, cooling system project I finally flew my B model again after a year last week.
I had to pull that motor to swap the stator due to it not charging. While I had it out I installed the Murle Williams aluminum radiator which is half the weight of the original. Finally I redid my ugly cowl. It turned into a 20 hr project of glassing, filling, and sanding.
First outing was to a private grass strip. Good times!
Looks real good Joey,  I been working on the wrecked C- Model and got it back in shape, picked up that 'Jab' and firewall forward from Alaska so something more to keep busy at. As if I need more to do. Then I could'nt turn down a deal on a K-F 7 fuselage with L under seat damage. Send some pictures later.
Good to hear it's back in the air Joey!
