WY kitfox Yamaha build
115 posts in this topic
I used aluminum... some think I’m crazy cause what if it catches fire, I don’t think that ends well in a fabric plane either way...  I didn’t weigh it.
BDFB8DEB-0B2D-44AB-A1F3-21807315C03D.jpegFinally! No small feet jokes please lol
Edited by 72chevy
Finished the suspension and coated in black zinc.
I do get some help occasionally...
I think we’re up to date now.
nice progress. Thanks for sharing!
Would you like to share some more info regarding your landing gear, like width and especially tube dimensions front and rear legs...
gorgeous plane
I am considering aluminum as well. Using a 1/8" fiberfrax layer, with a foil over the top could be worth considering on the engine side. Just something to consider. By the way, what aluminum alloy and thickness did you use?
There are some fire proof coating that you spray on that work amazingly well these days that Bruce at Backcountry was telling me about.  I should find out what it is.
Please share details of this spray if you find out what it is.
.040 5052
most of the tubing is .049, 1 1/4 inch for the front leg and 1 inch on the rear.  The legs are about 33 inches long and center to center on the tires is about 82 inches. Keep in mind this is hillbilly engineered...
I just used Galvanized tin for my fire wall cheap and available anywhere
Ok called Bruce it is available at ACS #05-02615.
Here is a link for video.
https://www.youtube.com/watch?v=GK2mDN7nKEE
this is a great Product,
dig the build thread, gonna be a bad ass bird.  Clean up on isle 3 as requested.
Thank you!  I think I’m finally catching a glimpse of light at the end of the tunnel occasionally.
Edited by 72chevy
Thats gonna be an awesome airplane when you get done. Thats some nice gear I need to get you to build me a set haha, I'm kinda dreading it.
Edited by FireFoxIV
72chevy, I have a mod 1/2 that the builder extended the very and rudder I believe how you did. When flying when rudder was pushed at cruise speed it deflected about 3 " this made me nervous so I added guy wires from top of horz to vert and this gave a warm fuzy. Just thought I would mention it.
I’ll keep an eye on it. I replaced the entire tail post with 3/4 .049 to match the model IV, although I don’t know what wall the IV used but I suspect.035, the rudder is from a model IV as well so hopefully I’m good.
.040 5052
I am strongly considering the 5052; chiefly for the weight savings, but the fire issue haunts me. Are you going to use something else to protect in the case of a fire?
I don’t plan to, I figure if I catch fire in a fabric plane I’m &@$# either way. If I get to worrying about it that product linked above looks pretty good.
Your build is truly inspiring. I have been plugging away on my scrappy build, but I must admit, I think you will have a show horse when she is done!
Curious. I am building a gear myself. Where is the 33" measured from?
