Avid MK IV Parts for Sale
14 posts in this topic
Parts available:
Complete Firewall Forward including Engine, engine mount, exhaust and radiators: 150hr Rotax 582 with C-Gearbox 3:1 ratio $2500                                  I can overhaul engine on request.
Right wing & flaperon $700
Wheel Fairings $80
Turtle Deck (some Damage) $50 sold
Horizontal Stab & Elevator $400
Control System Parts $?
3 Blade WarpDrive Hub $80
Garmin GTX320A Transponder $150 sold
6in Maule rubber tailwheel $200
6in Matco rubber tailwheel $200
Edited by flyboy-32
PM sent
Are there any damaged blades to go with that hub? I'm wanting to scan a semi complete blade and take some measurements off it as a base design. I can then widen it or make it more narrow, change the airfoil profiles, experiment with tip profiles and more within software and then laminate some wood blanks up and cut some test props out on the cnc. Is this the newer hub with the aluminum clam shell design?
Sorry I do not have any damaged blades.
Like to see a photo of the turtle deck
Do you have the tail leaf spring for the maule tailwheel. Im converting to a tailwheel. Already have the main gear and a maule tailwheel.
I would like more information on the transponder.   Antenna, Wire harness, tray?   Thanks Joe
I'm interested in the right wing and flaperon.
sold sorry
sold
call me 316-435-3837
I do have a tail spring.429200BC-1083-41FB-B761-A5E8A3A2531A.thu
flyboy32 give me a shout tomorrow when you get a chance. 850-525-8877 Thanks, Pat
PM sent for the hub.
