Triangle Side Windows
12 posts in this topic
Hey guys
I want to put similar side triangle windows on my Model C that is found on the Mark IVs .  I would appreciate a photo or two of what the installed window looks like close up. I understand my install may be different given mounting features.
Thanks in advance !
Philip
Hey guys
Thanks in advance !
Philip
Phillip,  I wish I knew if late model Kitfox aluminum triangle windows would fit your C - They fit the early model 1-4 Kitfoxes too.  I have a new, unused, pair that I would sell for half of new price, whatever that is.  EDMO
About the best pic I have. Fasteners on the fwd pillar. Turtledeck holds it down on the rear half. Lexan is riveted in.
Joey,  Can you get to the inside of the fuselage tubes to measure all 3 sides for me?  Thanks, EDMO
Yes sir but headed to Kauai Hawaii tomorrow for 6 days.
And I am sitting here in wet 40 degree weather and waiting for Spring to come about April 15 or later!  I am jealous, but hope you have a fun trip.  Thanks,  EDMO
Thanks guys and safe travel Joey! Any pics from the inside would be great to have as well.
This is what I found in my rebuild photo folder... there is nothing really complicated with the triangle window. In mine it was a fiber glass frame that you cover and fold the tissue/oratex around... On the right sided window, upper left corner (ok, triangle, upper corner...) you see the the corner of the uncovered fiber glass frame. You can make the frame in any thin material that is easy to cover.
Hope it helps...
Fred
Make your patterns with poster board first then trace it it thin aluminum cut and you have a window. Very easy you can do it. I Just cut a small piece of lexan and silicone it in the inside with a few aluminum rivets. Good to go.
Hey guys
Thanks in advance !
Philip
EDMO,
I'll take them if nobody else wants them.
Hey guys
Thanks in advance !
Philip
EDMO,
Good - Can you check with Kitfox for a price for a pair with aluminum frames?  I am having terrible headaches and ringing in ears from radiation - Just don't feel like doing any more than I have to right now.  EDMO
Hey guys
Thanks in advance !
Philip
EDMO,
Will call KF tomorrow.
