Who’s experimented with spinners?
16 posts in this topic
My new MK4 has the factory fiberglass spinner.  I left it off for the First flights so I could tweak my warp drive prop settings. I noticed it opens up the airway to the cheek radiators a bit. I’m thinking about ditching the big fiberglass spinner for the small skull cap warp spinner. Anyone know if a spinner gives any aerodynamic advantages or is it all cosmetic? The last pic is the smaller skull cap spinner
Edited by C5Engineer
Not a lot of info on spinners - My Ercoupe had a skullcap spinner - Suberavid had one on his plane.  Guessing that they remove some of the turbulence from the prop inner portion?   EDMO
I have tried to edit and add "drag" to this post twice, and it disappears each time I try - Reported it - Trying again now.  EDMO
Tried to change / edit "removes drag" to above and it don't work either - WTF!  EDMO
imho you have to think if the plane was a glider would you prefer to have? i'd vote for big spinner
I would think the biggest concern on the spinner is how much it affects your coolant temperatures - drag differences may be minimal no matter which one you use, but probably less than without spinner.  EDMO
Joey,  Maybe it is ease of removal of spinner that concerns you for adjusting WD blades - skull cap is lots easier.  EDMO
Joey,
My guess is the big vs little spinner makes no difference on a very draggy strutted aircraft like ours. Best way to tell is fly it without any spinner, and then with the big one and take a few careful identical performance points. The small spinner is clearly better than none, and it the difference between none and big is a slight diff, that proves the case.
Craig Catto was giving a presentation at Oshkosh focusing on analytical details/results on the subtleties of propeller design. I asked the question about spinner vs no spinner vs skull cap for my Bearhawk (designed for slow end of spectrum with 0-320). He said there would be absolutely no measurable difference whatsoever between the options.
As an AME I was surprised once to find out that on a Cessna C-172 you were NOT allowed to fly without spinner. Indeed the spinner on this aircraft is designed and important for engine cooling...
On another application like a pusher Long-ez, you can have up to 50 Lbs thrust increase in flight (if my memory's good) by installing an aerodynamically shaped spinner.....It was explained to me that the low pressure area around the prop hub can be greatly increased using this long and pointed spinner....
Obviously a tractor aircraft benefits from a clean spinner installation (where as little space is left between cowl and spinner and no "step" present) aerodynamically.....don't know by how much though....
My 1/2 cent
Edited by flywise
At least in streamlined tubes, a pointy front doesn't help as much as a pointy back.  Maybe that's why a front spinner doesn't help that much for improving performance/drag where the rear spinned did help.  JImChuk
In terms of drag the difference should not be noticeable but, as already mentionned, do keep an eye on your water temperature as the spinner (can) have a significant impact on the airflow to your radiators...
Edited by FredStork
Thanks guys. I’m not a huge fan of the huge fiberglass spinner. It weighs almost 3 lbs and has 9 screws and backing plates that can all  exaggerate an out of balance condition. You have to undo the prop entirely from the hub to install the backing plate it’s a pia. The skull cap has one screw and you can still make adjustments with it on. Oh ya it cost $140 from warp!!!
That looks suspiciously like a 4 stroke on that pallet mister.
For my private check ride I had about a hundred year old guy from the FAA as my examiner.  This was in the days before the feds contracted that work out to "super CFI" types.  We spent almost 2 hours just on the oral exam.  One of his questions that sticks in my mind went something like: "You are on a long cross country and someone damages your spinner while you are taking lunch. Can you remove the spinner and continue on your way home and then repair it?"
I said yes, I thought you could.  He then said WRONG and then showed me in the Piper Warrior operations manual mandatory equipment list that the spinner was listed.  It is required as a part of the cooling system.
Now, of course we are experimental so that's just not going to happen the same way but as others have pointed out, the spinner CAN BE part of the cooling system to direct flow through the cylinders.  Try it both ways.
By the way.  That check ride with him was almost all training.  He knew I could fly the airplane because he knew my instructor so we spent about an hour and a half doing commercial maneuvers, short approaches, cross wind landings, emergency descent technique through a hole in the overcast and other fun stuff.  He's gone West long ago but I'll always be grateful for the time I spent with him that day.
Edited by Emory Bored
You don't need the one from Warp!  Measure around your bolt heads and order cheaper one from Spruce - I think it may be about 7" diameter?  EDMO
There it goes again - Try to edit and the whole thing disappears - ??? - I tried to add that years ago guys were pulling down on Cessna spinners to check the travel on the nose gear and were putting the spinners out of balance - Cessna made an AD with a big NO-NO!  EDMO
