Building an Instrument panel
4 posts in this topic
OK, I am at the point of reinstalling parts into my Avid, my instrument panel was made out of some type of rigid plastic with the outside skins covered by aluminum. I see that the original panels were made of fiberglass and I have had one person suggest 1/16 inch lexan to build a new one. What have other people used? My panel weighs much more than it has to and since my diet isn't coming along the fastest I figure my plane needs one. What works for building a light weight panel.
AKFLYERBOB put a new panel in his out of .060 aluminum.. very light! mine is the same heavy aluminum as yours with the wood veneer crap on it that weighs a ton by itself. I picked up a fiberglass one but have not installed it in my plane yet. It is ALOT lighter than my stock panel
Mine is just thin aluminum and painted with some stuff similiar to bedliner in a can.
The alum, after all the holes are drilled weights very
little but is still rigid. I rivited the panel and dash
together and buffed it with 400 and warmed it a little
and painted it with wrinkle spray can paint.
I messed up a little, the wrinkle paint works well if the paint is put on thick, or wet. as painters call it, I
didn't have it wet enough in spots so it couldn't wrinkle.
But guess where most of the holes went.
It also doesn't blind you in the sun.
