Mark IV radiator bushings
Is there an outlet for rubber bushings for the Mark IV radiator mount? They are two peice. One side is 1 1/4 OD, 5/16 thick with a 3/8 hole in the center. The other is 1 1/4 OD, 7/16 thick and one side has a 3/4 raised area where it sets into the mount. Picture attached.
LEAF has some that look like yours.  Part # are H6141 thru H6144 depending on hardness.  Another part # is  H6150.  L  Look on page 21, center left column.   Sizes/dimentions are just above the mounts.  JImChuk
http://onlinecatalog.leadingedgeairfoils.com/app.php?RelId=6.4.3.11
Worse some to worse,  you can go to the rubber and gasket place and have them cut out. That's what I did with my engine mounts.
I have a post somewhere here but autozone carries a substitute for $4.00 they are for windshield wipers it's a 4 pack in the help parts section
Edited by chopndrag
I needed the smaller barry mounts for my radiator set up . I ordered a pair from aircraft spruce and they were to big . So while I was at the airport I decided to run to autozone for a couple things. I brought in a old mount and asked if they had anything like it . Come to find out windshield wiper motor mounts fit the bill . They cost 3.99 for 3 and worked great .
Thanks for the hook up Chopndrag. They worked great. 2017-07-17_19.24.39.thumb.jpg.5118d8f17c
No problem
