Seal part number needed for Kitfox hub
7 posts in this topic
Does anyone know the part # for the seal for the Kitfox hubs?  I know it's 1 9/16" OD, 3/4" ID, and 1/4" wide.  Can't seem to find one though.  JImChuk
Jim not sure if this will help or not.
Thanks Joey.  I did some searching, and that seal # is for a .875" ID.  Axels are 3/4".  Using the numbers gave me a lead, I was able to find .75" ID seals, and ordered a couple of them.  I have a set of Kifox hubs that didn't have bearings or the seals.  Got the bearings today.  Now the seals should be on the way.  Thanks, again.  JImChuk
Jim,  Can you please post the info on getting the 3/4" bearings and seals so someone can find it?  Thanks, EDMO
Here you go Ed.  This is what I ordered.  Hope it works.  JImChuk
SKF / CHICAGO RAWHIDE CR 7591 OIL SEAL, .750" x 1.575" x .250"
 Do you have the numbers for the bearings too, or were the ones Joey posted correct? - Where ordered?  EDMO
The bearings I ordered and got were a different #.  I used the # off my existing bearings.  I couldn't find a # on the seal, that's the reason for my original question.  Here is what I ordered through ebay.  Maybe Joey's hubs are different than mine.  The diameter of the bearing OD he shows is 1 25/32"  or 1.78125"  Which is just over 1 3/4".  Mine are just over 1 9/16"   JImChuk
A6075-A6157
Outer Diameter:1.5745in
