Avid aircraft serial number location
7 posts in this topic
Does anyone know where avid placed a serial number? I believe i have a model "A" plane....
Don't think you will find a serial # anywhere on the plane.  It is an A model though.  Welded in motor mount, shape of the door, 36" wide fuselage at the top of the seat, all would be different on a B or later models.  JImChuk
The builder determines the serial number and it should be on the data plate.  The kit serial number is nowhere on the parts.
I think Kitfox put the SN on the kit bill of sale, packing list, etc., which you may not have.  Congrats on joining "AK Avids".  EDMO
Mark makes a good point about the data plate.  Usually the builder used the kit serial # for the serial # of the plane.   Do you have the data plate? Or the N # for that matter, if it's still registered, the serial # will be on the FAA website data for your plane.  JImChuk
On each of the four KF I've owned (2 kits, 2 built), all had the kit manufacturer's kit s/n on the original invoice and related paperwork. Only the 4-1200 fuselage had the kit s/n stamped on it. My Avid Mk-IV and Avid+ also show the kit s/n on the invoice but did not have fuselage stamped. I agree most register using the kit number and builder name as plane manufacturer so the data plate or FAA registry may hold a clue. Too bad Brett is M.I.A., he has the old Avid sales records and could probably answer the question.
no data plate. purchased in the bones. no worries though. will give it my own number.....
