What model were the speed and aerobat wing introduced
2 posts in this topic
Anyone what model the speedwing and aerobat wing were introduced.  The history that I found here doesn't mention them until model C.  I have a possible B model that appears to have an aerobat wing, it is 23'8" long and undercambered, but it has 18" ribs on it.
TIA
Avid added different wing options sometime during the transition from B to C models and several kits ended up with a combination of different wing and fuselage parts. The aerobat wing is built using the same rib spacing as the heavy hauler but with the speedwing ribs (not undercamber ribs) and length, They also used a couple steel drag tubes instead of all aluminum.  Your wing appears to be a standard STOL wing but I'm not sure about the length
Edited by birddog486
