Issue putting KF wings on Avid
34 posts in this topic
Hey Leni, that makes sense. He was a smart guy to realize who might end up building his planes. Guess I'll think on it a little more, but it helps a lot to get feedback from others.
Oh, and you may have just surpassed joey on the square rooter claim to fame hahahaha
Not sure this is a good thing...  :lol:
so you say you would like less washout that is nice to hear, so when I start on my wings what do you think I should set them at. I think I convinced myself to just use the kitfox 1 ribs that I have just the way they are. keep this one simple and light. I do think I am going to stop the wing at 144 inches keep that in mind.
From memory I think most of the KF/Avid wings called for 1.5" or 1.75" washout. Most people seem to think that .5" would be sufficient.
I would definitely use the stock early KF ribs that you have. In fact since you have a complete stock kit, I would probably just try not to change anything. This will speed things up a lot. With the changes I've made, I'm still in "backwards mode". It will be nice to get things back to the completion level they would have come in the kit so I can go back to moving forward.
i come very late in , but why not working on avid wings? how they wrong built?
Not that Avid wings are built wrong, but Kitfox wings are about 3 feet (almost 1 meter) longer span and give more lift and slower landings.  Kitfox is just an Avid clone for the first 3 models.  The later model 4 Classic was a heavier-built plane with a different wing rib.
ok, i believe KF 123 are longer than avid and more tail surface. i dunno if so long wings are good with our little bird, specially with model ABC. I suspect more adverse yaw, inertia, and lower response in handling
The men who fly back-country and high altitudes need a larger wing for more lift, shorter takeoff and slower landings.  The Kitfox wing helps.
EdMo
Are Avid HH or STOL wings that hard to find?
So wondering what did you end up doing because im in that same situation now all these years later with a MK4, Love to know
