Avid C 3 view drawing
5 posts in this topic
here is the 3 View drawing for an Avid Model C Tail Dragger
Avid Tail Dragger 3 view.pdf
Looks like none of the files marked as pdf. will open.  Adobe's latest program says the file is damaged.. or not recognized. Any chance someone could go through and change all marked as pdf. to something that works?
thanks much
Tried on another computer and the message this time says "the file is damaged and cannot be repaired"...
aarrrg.
I had this problem with some other PDF's on the site.  It was decided that an upgrade or problem in the past had damaged them.  The original poster was able to reupload them, and the worked after that.
Mark
Trying to go back through all posts and reload the pdfs is a task I am not willing nor have the time to do.. when one is found, you can try to bring up to the top by replying to the topic and perhaps they can upload it. My laptop died so I lost a ton of files that I had posted.
